Constrained Control Design for Linear Systems with Geometric Adversary Constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper is concerned with the optimal control of linear dynamical systems in the presence of a set of adversary constraints. One of the novelties is the type of constraints introduced in the receding horizon optimization problem. These constraints can be considered as adversary by their non convex characteristics which make the convergence of the systems' dynamics towards the "natural" equilibrium position an impossible task. In this case, the default equilibrium point has to be replaced by a set of equilibrium points or even to accept the existence of limit cycles. The present paper proposes a dual-mode control strategy which builds on an optimization based controller and a fixed constrained control law whenever the adversary constraints are activated. Furthermore, the method which exhibits effective performance builds on invariance concepts and proves to be related to the classical eigenstructure assignment problems. In order to illustrate the benefits of the proposed method, typical applications involving the control of Multi-Agent Systems are considered.
IP_IFAC SSSC_fv.pdf (445.18 Ko) Télécharger le fichier
hal-00794361 , version 1 (16-03-2020)
Ionela Prodan, George Bitsoris, Sorin Olaru, Cristina Stoica, Silviu-Iulian Niculescu. Constrained Control Design for Linear Systems with Geometric Adversary Constraints. IFAC 2013 - 5th Symposium on System Structure and Control, Feb 2013, Grenoble, France. pp.815-820, ⟨10.3182/20130204-3-FR-2033.00190⟩. ⟨hal-00794361⟩
197 Consultations
97 Téléchargements
