A sufficient condition for partial ensemble controllability of bilinear Schrödinger equations with bounded coupling terms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This note presents a sufficient condition for partial approximate ensemble controllability of a set of bilinear conservative quantum systems in an infinite dimensional Hilbert space. The proof relies on classical geometric and averaging control techniques applied on finite dimensional approximation of the infinite dimensional system. The results are illustrated with the planar rotation of a linear molecule.
Simultane03.pdf (153.26 Ko) Télécharger le fichier
hal-00795862 , version 1 (01-03-2013)
hal-00795862 , version 2 (07-03-2013)
Thomas Chambrion. A sufficient condition for partial ensemble controllability of bilinear Schrödinger equations with bounded coupling terms. Conference on Decision and Control, Dec 2013, Florence, Italy. pp.3708-3713. ⟨hal-00795862v2⟩
361 Consultations
105 Téléchargements
