Final CONNECT Architecture - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2012
Interoperability remains a fundamental challenge when connecting heterogeneous systems which encounter and spontaneously communicate with one another in pervasive computing environments. This challenge is exasperated by the highly heterogeneous technologies employed by each of the interacting parties, i.e., in terms of hardware, operating system, middleware protocols, and application protocols. The key aim of the CONNECT project is to drop this heterogeneity barrier and achieve universal interoperability. Here we report on the revised CONNECT architecture, highlighting the integration of the work carried out to integrate the CONNECT enablers developed by the different partners; in particular, we present the progress of this work towards a finalised concrete architecture. In the third year this architecture has been enhanced to: i) produce concrete CONNECTors, ii) match networked systems based upon their goals and intent, and iii) use learning technologies to find the affordance of a system. We also report on the application of the CONNECT approach to streaming based systems, further considering exploitation of CONNECT in the mobile environment.
CONNECT_Deliverable_D1_4.pdf (7.63 Mo) Télécharger le fichier
hal-00796387 , version 1 (04-03-2013)
  • HAL Id : hal-00796387 , version 1
Emil-Mircea Andriescu, Amel Bennaceur, Gordon S. Blair, Antonello Calabro, Paul Grace, et al.. Final CONNECT Architecture. [Research Report] 2012. ⟨hal-00796387⟩
319 Consultations
250 Téléchargements
