The Reduced Hartree-Fock Model for Short-Range Quantum Crystals with Nonlocal Defects - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Annales Henri Poincaré Année : 2013
In this article, we consider quantum crystals with defects in the reduced Hartree-Fock framework. The nuclei are supposed to be classical particles arranged around a reference periodic configuration. The perturbation is assumed to be small in amplitude, but need not be localized in a specific region of space or have any spatial invariance. Assuming Yukawa interactions, we prove the existence of an electronic ground state, solution of the self-consistent field equation. Next, by studying precisely the decay properties of this solution for local defects, we are able to expand the density of states of the nonlinear Hamiltonian of a system with a random perturbation of Anderson-Bernoulli type, in the limit of low concentration of defects. One important step in the proof of our results is the analysis of the dielectric response of the crystal to an effective charge perturbation.
article_5_Mars_12.pdf (416.76 Ko) Télécharger le fichier
hal-00797094 , version 1 (05-03-2013)
Salma Lahbabi. The Reduced Hartree-Fock Model for Short-Range Quantum Crystals with Nonlocal Defects. Annales Henri Poincaré, 2013, pp.1-50. ⟨10.1007/s00023-013-0283-3⟩. ⟨hal-00797094⟩
194 Consultations
204 Téléchargements
