Floating-point arithmetic in the Coq system - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Information and Computation Année : 2012
The process of proving some mathematical theorems can be greatly reduced by relying on numerically-intensive computations with a certified arithmetic. This article presents a formalization of floating-point arithmetic that makes it possible to efficiently compute inside the proofs of the Coq system. This certified library is a multi-radix and multi-precision implementation free from underflow and overflow. It provides the basic arithmetic operators and a few elementary functions.
article.pdf (291.96 Ko) Télécharger le fichier
hal-00797913 , version 1 (07-03-2013)
Guillaume Melquiond. Floating-point arithmetic in the Coq system. Information and Computation, 2012, 216, pp.14-23. ⟨10.1016/j.ic.2011.09.005⟩. ⟨hal-00797913⟩
234 Consultations
299 Téléchargements
