Space-only hyperbolic approximation of the Vlasov equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Proceedings Année : 2013
We construct an hyperbolic approximation of the Vlasov equation in which the dependency on the velocity variable is removed. The resulting model enjoys interesting conservation and entropy properties. It can be numerically solved by standard schemes for hyperbolic systems. We present numerical results for one-dimensional classical test cases in plasma physics: Landau damping, two-stream instability
vlasov-hyper.pdf (704.12 Ko) Télécharger le fichier
hal-00797974 , version 1 (07-03-2013)
Philippe Helluy, Nhung Pham, Anaïs Crestetto. Space-only hyperbolic approximation of the Vlasov equation. ESAIM: Proceedings, 2013, 43, pp.17-36. ⟨10.1051/proc/201343002⟩. ⟨hal-00797974⟩
283 Consultations
297 Téléchargements
