Tradeoffs for reliable quantum information storage in surface codes and color codes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The family of hyperbolic surface codes is one of the rare families of quantum LDPC codes with non-zero rate and unbounded minimum distance. First, we introduce a family of hyperbolic color codes. This produces a new family of quantum LDPC codes with non- zero rate and with minimum distance logarithmic in the blocklength. Second, we show that the parameters [[n, k, d]] of surface codes and color codes satisfy kd^2 ≤ C(log k)^2n, where C is a constant that depends only on the row weight of the parity-check matrix. Our results prove that the best asymptotic minimum distance of LDPC surface codes and color codes with non-zero rate is logarithmic in the length.
Delfosse_tradeoffs.pdf (337.83 Ko) Télécharger le fichier
hal-00798030 , version 1 (07-03-2013)
Nicolas Delfosse. Tradeoffs for reliable quantum information storage in surface codes and color codes. IEEE International Symposium on Information Theory, ISIT 2013, Jul 2013, Istanbul, Turkey. ⟨10.1109/ISIT.2013.6620360⟩. ⟨hal-00798030⟩
396 Consultations
149 Téléchargements
