Canonized Rewriting and Ground AC Completion Modulo Shostak Theories : Design and Implementation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Logical Methods in Computer Science Année : 2012
AC-completion efficiently handles equality modulo associative and commutative function symbols. When the input is ground, the procedure terminates and provides a decision algorithm for the word problem. In this paper, we present a modular extension of ground AC-completion for deciding formulas in the combination of the theory of equality with user-defined AC symbols, uninterpreted symbols and an arbitrary signature disjoint Shostak theory X. Our algorithm, called AC(X), is obtained by augmenting in a modular way ground AC-completion with the canonizer and solver present for the theory X. This integration rests on canonized rewriting, a new relation reminiscent to normalized rewriting, which integrates canonizers in rewriting steps. AC(X) is proved sound, complete and terminating, and is implemented to extend the core of the Alt-Ergo theorem prover.
hal-00798082 , version 1 (08-03-2013)
Sylvain Conchon, Evelyne Contejean, Mohamed Iguernelala. Canonized Rewriting and Ground AC Completion Modulo Shostak Theories : Design and Implementation. Logical Methods in Computer Science, 2012, 8 (3:16), pp.1-29. ⟨10.2168/LMCS-8(3:16)2012⟩. ⟨hal-00798082⟩
140 Consultations
0 Téléchargements
