Error estimate for time-explicit finite volume approximation of strong solutions to systems of conservation laws - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Numerical Analysis Année : 2016
We study the finite volume approximation of strong solutions to nonlinear systems of conservation laws. We focus on time-explicit schemes on unstructured meshes, with entropy satisfying numerical fluxes. The numerical entropy dissipation is quantified at each interface of the mesh, which enables to prove a weak–BV estimate for the numerical approximation under a strengthen CFL condition. Then we derive error estimates in the multidimensional case, using the relative entropy between the strong solution and its finite volume approximation. The error terms are carefully studied, leading to a classical $h^1/4$ estimate in $L^2$ under this strengthen CFL condition.
Entrel-hal.pdf (277.72 Ko) Télécharger le fichier
hal-00798287 , version 1 (08-03-2013)
hal-00798287 , version 2 (08-07-2015)
hal-00798287 , version 3 (05-02-2016)
Clément Cancès, Hélène Mathis, Nicolas Seguin. Error estimate for time-explicit finite volume approximation of strong solutions to systems of conservation laws. SIAM Journal on Numerical Analysis, 2016, 54 (2), pp.1263-1287. ⟨10.1137/15M1029886⟩. ⟨hal-00798287v3⟩
612 Consultations
562 Téléchargements
