Controllability and Optimal Strokes for N-link Micro-swimmer - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we focus on the N-link swimmer, a generalization of the classical 3-link Purcell swimmer. We use the Resistive Force Theory to express the equation of motion in a fluid with a low Reynolds number, and prove that the swimmer is controllable in the whole plane for N greater or equal than 3 and for almost every set of stick lengths. As a direct result, there exists an optimal swimming strategy to reach a desired configuration in minimum time. Numerical experiments for N=3 (Purcell swimmer) suggest that the optimal strategy is periodic, namely a sequence of identical strokes. Our results indicate that this candidate for an optimal stroke indeed gives a better displacement speed than the classical Purcell stroke.
CDC-final.pdf (290.99 Ko) Télécharger le fichier
hal-00798363 , version 1 (08-03-2013)
hal-00798363 , version 2 (26-07-2013)
hal-00798363 , version 3 (27-04-2016)
Laetitia Giraldi, Pierre Martinon, Marta Zoppello. Controllability and Optimal Strokes for N-link Micro-swimmer. 52nd IEEE Conference on Decision and Control, Dec 2013, Firenze, Italy. ⟨10.1109/CDC.2013.6760480⟩. ⟨hal-00798363v3⟩
601 Consultations
640 Téléchargements
