Hamilton-Jacobi-Bellman Equations on Multi-Domains - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2013
A system of Hamilton Jacobi (HJ) equations on a partition of $\R^d$ is considered, and a uniqueness and existence result of viscosity solution is analyzed. While the notion of viscosity notion is by now well known, the question of uniqueness of solution, when the Hamiltonian is discontinuous, remains an important issue. A uniqueness result has been derived for a class of problems, where the behavior of the solution, in the region of discontinuity of the Hamiltonian, is assumed to be irrelevant and can be ignored (see reference [10]) . Here, we provide a new uniqueness result for a more general class of Hamilton-Jacobi equations.
Rao-Zidani-FinalVersion.pdf (537.02 Ko) Télécharger le fichier
hal-00803108 , version 1 (21-03-2013)
Zhiping Rao, Hasnaa Zidani. Hamilton-Jacobi-Bellman Equations on Multi-Domains. K. Bredies; C. Clason; K. Kunisch; G. von Winckel. Control and Optimization with PDE Constraints, 164, Springer, pp.93--116, 2013, International Series of Numerical Mathematics, 978-3-0348-0630-5. ⟨10.1007/978-3-0348-0631-2_6⟩. ⟨hal-00803108⟩
440 Consultations
546 Téléchargements
