Multifidelity variance reduction for pick-freeze Sobol index estimation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
Many mathematical models involve input parameters, which are not precisely known. Global sensitivity analysis aims to identify the parameters whose uncertainty has the largest impact on the variability of a quantity of interest (output of the model). One of the statistical tools used to quantify the influence of each input variable on the output is the Sobol sensitivity index, which can be estimated using a large sample of evaluations of the output. We propose a variance reduction technique, based on the availability of a fast approximation of the output, which can enable significant computational savings when the output is costly to evaluate.
Article_Multifid.pdf (131.69 Ko) Télécharger le fichier
hal-00804119 , version 1 (25-03-2013)
Alexandre Janon. Multifidelity variance reduction for pick-freeze Sobol index estimation. 2013. ⟨hal-00804119⟩
275 Consultations
192 Téléchargements
