Cut-Generating Functions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In optimization problems such as integer programs or their relaxations, one encounters feasible regions that are the inverse images of a specific closed set S by a linear mapping. One would like to generate valid inequalities that cut off infeasible solutions. Formulas for such inequalities can be obtained through cut-generating functions. This paper presents a formal theory of minimal cut-generating functions and maximal S-free sets which is valid independently of the particular S. This theory relies on tools of convex analysis.
cut-generating-functions.pdf (137.59 Ko) Télécharger le fichier
hal-00804175 , version 1 (25-03-2013)
Michele Conforti, Gérard Cornuéjols, Aris Daniilidis, Claude Lemaréchal, Jérôme Malick. Cut-Generating Functions. IPCO 2013 - 16th International Conference on Integer Programming and Combinatorial Optimization, Mar 2013, Valparaíso, Chile. pp.123-132, ⟨10.1007/978-3-642-36694-9_11⟩. ⟨hal-00804175⟩
523 Consultations
153 Téléchargements
