Reconstructing the potential for the 1D Schrödinger equation from boundary measurements
We consider the inverse problem of determining the potential in the dynamical Schrödinger equation on the interval by the measurement on the boundary. We use the Boundary Control method to recover the spectrum of the problem from the observation at either left or right end points. Using the specificity of the one-dimensional situation we recover the spectral function, reducing the problem to the classical one which could be treated by known methods. We apply the algorithm to the situation when only the finite number of eigenvalues are known and prove the convergence of the method.
