A Note on k-support Norm Regularized Risk Minimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
The k-support norm has been recently introduced to perform correlated sparsity regularization. Although Argyriou et al. only reported experiments using squared loss, here we apply it to several other commonly used settings resulting in novel machine learning algorithms with interesting and familiar limit cases. Source code for the algorithms described here is available.
ksupport.pdf (244.11 Ko) Télécharger le fichier
hal-00804592 , version 1 (25-03-2013)
hal-00804592 , version 2 (27-03-2013)
Matthew Blaschko. A Note on k-support Norm Regularized Risk Minimization. 2013. ⟨hal-00804592v2⟩
410 Consultations
405 Téléchargements
