A gate level methodology for efficient statistical leakage estimation in complex 32nm circuits - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A fast and accurate statistical method that estimates at gate level the leakage power consumption of CMOS digital circuits is demonstrated. Means, variances and correlations of logic gate leakages are extracted at library characterization step, and used for subsequent circuit statistical computation. In this paper, the methodology is applied to an eleven thousand cells ST test IP. The circuit leakage analysis computation time is 400 times faster than a single fast-Spice corner analysis, while providing coherent results.
DATE2013.pdf (290.11 Ko) Télécharger le fichier
hal-00805478 , version 1 (28-03-2013)
Smriti Joshi, Anne Lombardot, Marc Belleville, Edith Beigné, Stéphane Girard. A gate level methodology for efficient statistical leakage estimation in complex 32nm circuits. DATE 2013 - Design, Automation and Test in Europe, Mar 2013, Grenoble, France. pp.1056-1057, ⟨10.7873/DATE.2013.221⟩. ⟨hal-00805478⟩
352 Consultations
274 Téléchargements
