Perfect Conductor and Impedance Boundary Condition Corrections via a Finite Element Subproblem Method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A finite element subproblem method is developed to correct the inaccuracies proper to perfect conductor and impedance boundary condition models, in particular near edges and corners of conductors, for a large range of conductivities and frequencies. Local corrections, supported by fine local meshes, can be obtained from each model to a more accurate one, allowing efficient extensions of their domains of validity.
Compumag2013-Dular_PerfectConductor.pdf (588.74 Ko) Télécharger le fichier
hal-00807078 , version 1 (02-04-2013)
  • HAL Id : hal-00807078 , version 1
Patrick Dular, Victor Péron, Ronan Perrussel, Laurent Krähenbühl, Christophe Geuzaine. Perfect Conductor and Impedance Boundary Condition Corrections via a Finite Element Subproblem Method. Compumag 2013, Jun 2013, Budapest, Hungary. pp.866. ⟨hal-00807078⟩
378 Consultations
537 Téléchargements
