R2-EMOA: Focused Multiobjective Search Using R2-Indicator-Based Selection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
An indicator-based evolutionary multiobjective optimization algorithm (EMOA) is introduced which incorporates the contribution to the unary R2-indicator as the secondary selection criterion. First experiments indicate that the R2-EMOA accurately approximates the Pareto front of the considered continuous multiobjective optimization problems. Furthermore, decision makers' preferences can be included by adjusting the weight vector distributions of the indicator which results in a focused search behavior.
LION2013_authorversion.pdf (99.13 Ko) Télécharger le fichier
hal-00807901 , version 1 (25-03-2014)
Heike Trautmann, Tobias Wagner, Dimo Brockhoff. R2-EMOA: Focused Multiobjective Search Using R2-Indicator-Based Selection. Learning and Intelligent OptimizatioN Conference (LION 7), Jan 2013, Catania, Italy. pp.70-74, ⟨10.1007/978-3-642-44973-4_8⟩. ⟨hal-00807901⟩
214 Consultations
899 Téléchargements
