Integrative models for analyzing jointly shoot growth and branching patterns - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The branching pattern of a shoot may be influenced by numerous factors varying along the shoot such as the internode length, the leaf surface or the local curvature. We introduce a generalization of hidden semi-Markov chains for categorical response variables that incorporates explanatory variables varying with the index parameter. Using this model, we demonstrate the influence of the growth pattern of a shoot on its immediate branching.
Peyhardi-7FSPM-2013_1.pdf (154.22 Ko) Télécharger le fichier
hal-00808264 , version 1 (03-06-2020)
  • HAL Id : hal-00808264 , version 1
  • PRODINRA : 326352
Jean Peyhardi, Evelyne Costes, Yves Caraglio, Pierre-Eric Lauri, Catherine Trottier, et al.. Integrative models for analyzing jointly shoot growth and branching patterns. 7th International Workshop on Functional Structural Plant Models, Jun 2013, Saariselkä, Finland. pp.207-209. ⟨hal-00808264⟩
404 Consultations
33 Téléchargements
