A unifying framework for specifying generalized linear models for categorical data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In the context of categorical data analysis, the case of nominal and ordinal data has been investigated in depth while the case of partially ordered data has been comparatively neglected. We first propose a new specification of generalized linear models (GLMs) for categorical response variables which en- compasses all the classical models such as multinomial logit, odds proportional or continuation ratio models but also led us to identify new GLMs. This unifying framework makes the different GLMs easier to compare and combine. We then define the more general class of partitioned conditional GLMs for categorical re- sponse variables. This new class enables to take into account the case of partially ordered data by combining nominal and ordinal GLMs.
2013_Peyhardi_StatisticalModeling_1.pdf (549 Ko) Télécharger le fichier
hal-00808270 , version 1 (03-06-2020)
  • HAL Id : hal-00808270 , version 1
  • PRODINRA : 326666
Jean Peyhardi, Catherine Trottier, Yann Guédon. A unifying framework for specifying generalized linear models for categorical data. 28th International Workshop on Statistical Modeling, Università degli Studi di Palermo. Palerme, ITA., Jul 2013, Palermo, Italy. pp.331-335. ⟨hal-00808270⟩
364 Consultations
38 Téléchargements
