Uncertainty Quantification for Modal Parameters from Stochastic Subspace Identification on Multi-Setup Measurements - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mechanical Systems and Signal Processing Année : 2013
In operational modal analysis, the modal parameters (natural frequencies, damping ratios and mode shapes), obtained with stochastic subspace identification from ambient vibration measurements of structures, are subject to statistical uncertainty. It is hence necessary to evaluate the uncertainty bounds of the obtained results, which can be done by a first-order perturbation analysis. To obtain vibration measurements at many coordinates of a structure with only a few sensors, it is common practice to use multiple sensor setups for the measurements. Recently, a multi-setup subspace identification algorithm has been proposed that merges the data from different setups prior to the identification step to obtain one set of global modal parameters, taking the possibly different ambient excitation characteristics between the measurements into account. In this paper, an algorithm is proposed that efficiently estimates the covari-ances on modal parameters obtained from this multi-setup subspace identification. The new algorithm is validated on multi-setup ambient vibration data of the Z24 Bridge, benchmark of the COST F3 European network.
multi_setup.pdf (618.09 Ko) Télécharger le fichier
hal-00811706 , version 1 (20-04-2020)
Michael Döhler, Xuan-Binh Lam, Laurent Mevel. Uncertainty Quantification for Modal Parameters from Stochastic Subspace Identification on Multi-Setup Measurements. Mechanical Systems and Signal Processing, 2013, 36 (2), pp.562--581. ⟨10.1016/j.ymssp.2012.11.011⟩. ⟨hal-00811706⟩
202 Consultations
259 Téléchargements
