Motion similarity measure between video sequences using multivariate time series modeling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The analysis and interpretation of video contents is an important component of modern vision applications such as surveillance, motion synthesis and web-based user interfaces. A requirement shared by these very different applications is the ability to learn statistical models of appearance and motion from a collection of videos, and then use them for recognizing actions or persons in a new video. Measuring the similarity and dissimilarity between video sequences is crucial in any video sequences analysis and decision-making process. Furthermore, many data analysis processes effectively deal with moving objects and need to compute the similarity between trajectories. In this paper, we propose a similarity measure for multivariate time series using the Euclidean distance based on Vector Autoregressive (VAR) models. The proposed approach allows us to identify and recognize actions of persons in video sequences. The performance of our methodology is tested on a real dataset.
Fichier non déposé
hal-00812128 , version 1 (11-04-2013)
Rémi Auguste, Ahmed El Ghini, Ioan Marius Bilasco, Nacim Ihaddadene, Chabane Djeraba. Motion similarity measure between video sequences using multivariate time series modeling. International Conference on Machine and Web Intelligence (ICMWI), 2010, Oct 2010, Algiers, Algeria. pp.292-296, ⟨10.1109/ICMWI.2010.5647919⟩. ⟨hal-00812128⟩
225 Consultations
0 Téléchargements
