Risk indicators with several lines of business: comparison, asymptotic behavior and applications to optimal reserve allocation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Annales de l'ISUP Année : 2014
In a multi-dimensional risk model with dependent lines of business, we propose to allocate capital with respect to the minimization of some risk indicators. These indicators are sums of expected penalties due to the insolvency of a branch while the global reserve is either positive or negative. Explicit formulas in the case of two branches are obtained for several models independent exponential, correlated Pareto). The asymptotic behavior (as the initial capital goes to infinity) is studied. For higher dimension and several periods, no explicit expression is available. Using a stochastic algorithm, we get estimations of the allocation, compare the different allocations and study the impact of dependence.
CSPV_soumis.pdf (295.94 Ko) Télécharger le fichier
hal-00816894 , version 1 (23-04-2013)
  • HAL Id : hal-00816894 , version 1
Peggy Cénac, Stéphane Loisel, Véronique Maume-Deschamps, Clémentine Prieur. Risk indicators with several lines of business: comparison, asymptotic behavior and applications to optimal reserve allocation. Annales de l'ISUP, 2014, 58 (3), pp.3-26. ⟨hal-00816894⟩
776 Consultations
235 Téléchargements
