Nogood-Based Asynchronous Forward Checking Algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Constraints Année : 2013
We propose two new algorithms for solving Distributed Constraint Satisfaction Problems (DisCSPs). The first algorithm, AFC-ng, is a nogood-based version of Asynchronous Forward Checking (AFC). Besides its use of nogoods as justification of value removals, AFC-ng allows simultaneous backtracks going from different agents to different destinations. The second algorithm, Asynchronous Forward Checking Tree (AFC- tree), is based on the AFC-ng algorithm and is performed on a pseudo-tree ordering of the constraint graph. AFC-tree runs simultaneous search processes in disjoint problem subtrees and exploits the parallelism inherent in the problem. We prove that AFC-ng and AFC-tree only need polynomial space. We compare the performance of these algorithms with other DisCSP algorithms on random DisCSPs and instances from real benchmarks: sensor networks and distributed meeting scheduling. Our experiments show that AFC-ng improves on AFC and that AFC-tree outperforms all compared algorithms, particularly on sparse problems.
constraints13-afcng.pdf (670.89 Ko) Télécharger le fichier
hal-00816928 , version 1 (23-04-2013)
Mohamed Wahbi, Redouane Ezzahir, Christian Bessiere, El Houssine Bouyakhf. Nogood-Based Asynchronous Forward Checking Algorithms. Constraints, 2013, 18 (3), pp.404-433. ⟨10.1007/s10601-013-9144-4⟩. ⟨hal-00816928⟩
680 Consultations
553 Téléchargements
