Optimization of the separation of two species in a chemostat - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automatica Année : 2014
In this work, we study a two species chemostat model with one limiting substrate, and our aim is to optimize the selection of the species of interest. More precisely, the objective is to find an optimal feeding strategy in order to reach in minimal time a target where the concentration of the first species is significantly larger than the concentration of the other one. Thanks to Pontryagin maximum principle, we introduce a singular feeding strategy which allows to reach the target, and we prove that the feedback control provided by this strategy is optimal whenever initial conditions are chosen in the invariant attractive manifold of the system. The optimal synthesis of the problem in presence of more than one singular arc and for initial conditions outside this set is also investigated.
preprint-HAL.pdf (704.7 Ko) Télécharger le fichier
hal-00817147 , version 1 (23-04-2013)
hal-00817147 , version 2 (25-04-2013)
Térence Bayen, Francis Mairet. Optimization of the separation of two species in a chemostat. Automatica, 2014, 50 (4), pp.1243-1248. ⟨10.1016/j.automatica.2014.02.024⟩. ⟨hal-00817147v2⟩
890 Consultations
420 Téléchargements
