A PDE-like Toy-Model of Territory Working - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2017
This note introduces a PDE-like Toy-Model that embeds several aspects of Territory Working. The long term goal is to build a software tool that behaves like a Territory, and in particular that incorporates its multi-scale-in-time-and-space nature, in order to make simulations, to explore scenarios, to foresee policy impacts, to help to make a decision when facing a change in the environment or in cultural behavior, {\it etc.}. The aim of this note is prove that the concept of building a model that couple Systemic Approach and PDE tools to achieve the evoked long term goal is possible.
ToyModelV4.pdf (1.27 Mo) Télécharger le fichier
hal-00817522 , version 1 (24-04-2013)
hal-00817522 , version 2 (15-10-2013)
Emmanuel Frenod. A PDE-like Toy-Model of Territory Working. Nicolas Debarsy; Stéphane Cordier; Cem Ertur; François Nemo; Déborah Nourrit-Lucas; Gérard Poisson; Christel Vrain. Understanding Interactions in Complex Systems - Toward a Science of Interaction, Cambridge Scholar Publishing, pp.37--47, 2017, Understanding Interactions in Complex Systems - Toward a Science of Interaction, 978-1-4438-9496-8. ⟨hal-00817522v2⟩
601 Consultations
105 Téléchargements
