Concept-based query transformation based on semantic centrality in semantic peer-to-peer environment - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Query transformation is a serious hurdle on semantic peer-to-peer environment. The problem is that the transformed queries might lose some information from the original one, as continuously traveling p2p networks. We mainly consider two factors; i) number of transformations and// ii) quality of ontology alignment. In this paper, we propose semantic centrality (SC) measurement meaning the power of semantic bridging on semantic p2p environment. Thereby, we want to build semantically cohesive user subgroups, and find out the best peers for query transformation, i.e., minimizing information loss. We have shown an example for retrieving image resources annotated on p2p environment by using query transformation based on SC.
Autre [cs.OH]
jung2007b.pdf (134.33 Ko) Télécharger le fichier
hal-00817812 , version 1 (25-04-2013)
Jason Jung, Antoine Zimmermann, Jérôme Euzenat. Concept-based query transformation based on semantic centrality in semantic peer-to-peer environment. Proc. 9th Conference on Asia-Pacific web (APWeb), Jun 2007, Huang Shan, China. pp.622-629, ⟨10.1007/978-3-540-72524-4_64⟩. ⟨hal-00817812⟩
351 Consultations
123 Téléchargements
