R-IAC: Robust intrinsically motivated exploration and active learning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Autonomous Mental Development Année : 2009
IAC was initially introduced as a developmental mechanism allowing a robot to self-organize developmental trajectories of increasing complexity without pre-programming the particular developmental stages. In this paper, we argue that IAC and other intrinsically motivated learning heuristics could be viewed as active learning algorithms that are particularly suited for learning forward models in unprepared sensorimotor spaces with large unlearnable subspaces. Then, we introduce a novel formulation of IAC, called R-IAC (Robust Intelligent Adaptive Curiosity), and show that its performances as an intrinsically motivated active learning algorithm are far superior to IAC in a complex sensorimotor space where only a small subspace is neither unlearnable nor trivial. We also show results in which the learnt forward model is reused in a control scheme. Finally, an open-source accompanying software containing these algorithms as well as tools to reproduce all the experiments presented in this paper is made publicly available. Index Terms-- active learning, intrinsic motivation, exploration, developmental robotics, artificial curiosity, sensorimotor learning.
TAMDBaranesOudeyer09.pdf (1.03 Mo) Télécharger le fichier
hal-00818174 , version 1 (26-04-2013)
Adrien Baranes, Pierre-Yves Oudeyer. R-IAC: Robust intrinsically motivated exploration and active learning. IEEE Transactions on Autonomous Mental Development, 2009, 1 (3), pp.155-169. ⟨10.1109/TAMD.2009.2037513⟩. ⟨hal-00818174⟩
259 Consultations
492 Téléchargements
