A computational diffusion MRI and parametric dictionary learning framework for modeling the diffusion signal and its features - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Medical Image Analysis Année : 2013
In this work, we first propose an original and efficient computational framework to model continuous diffusion MRI (dMRI) signals and analytically recover important diffusion features such as the Ensemble Average Propagator (EAP) and the Orientation Distribution Function (ODF). Then, we develop an efficient parametric dictionary learning algorithm and exploit the sparse property of a well-designed dictionary to recover the diffusion signal and its features with a reduced number of measurements. The properties and potentials of the technique are demonstrated using various simulations on synthetic data and on human brain data acquired from 7-T and 3-T scanners. It is shown that the technique can clearly recover the dMRI signal and its features with a much better accuracy compared to state-of-the-art approaches, even with a small and reduced number of measurements. In particular, we can accurately recover the ODF in regions of multiple fiber crossing, which could open new perspectives for some dMRI applications such as fiber tractography.
merlet-etal-2013.pdf (6.36 Mo) Télécharger le fichier
hal-00820817 , version 1 (07-05-2013)
Sylvain L. Merlet, Emmanuel Caruyer, Aurobrata Ghosh, Rachid Deriche. A computational diffusion MRI and parametric dictionary learning framework for modeling the diffusion signal and its features. Medical Image Analysis, 2013, pp.MEDIMA779. ⟨10.1016/j.media.2013.04.011⟩. ⟨hal-00820817⟩
222 Consultations
325 Téléchargements
