Computing representations for radicals of finitely generated differential ideals - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Applicable Algebra in Engineering, Communication and Computing Année : 2009
This paper deals with systems of polynomial di erential equations, ordinary or with partial derivatives. The embedding theory is the di erential algebra of Ritt and Kolchin. We describe an algorithm, named Rosenfeld-Gröbner, which computes a representation for the radical p of the diff erential ideal generated by any such sys- tem . The computed representation constitutes a normal simpli er for the equivalence relation modulo p (it permits to test embership in p). It permits also to compute Taylor expansions of solutions of . The algorithm is implemented within a package in MAPLE.
blopV2.pdf (412.81 Ko) Télécharger le fichier
hal-00820902 , version 1 (06-05-2013)
François Boulier, Daniel Lazard, François Ollivier, Michel Petitot. Computing representations for radicals of finitely generated differential ideals. Applicable Algebra in Engineering, Communication and Computing, 2009, 20 (1), pp.73-121. ⟨10.1007/s00200-009-0091-7⟩. ⟨hal-00820902⟩
586 Consultations
376 Téléchargements
