Mechanical simulation of the Exomars rover using Siconos in 3DROV - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents ongoing work at INRIA in collaboration with TRASYS on the mechanical modelling and simulation of planetary rovers. We focus our presentation on an specific approach used the INRIA SICONOS software. This approach [2] based on the nonsmooth Mechanics theory is dedicated to the modeling and the simulation of multi-body systems with joints, hard contacts, Coulomb's friction and impacts. In addition, software integration aspects are considered defining and implementing generic software interfaces between SICONOS and external 3D tools. The approach is applied to the rover planetary operations enhancing the fidelity and the genericity of the ExoMars existing rover mechanical models
siconos3drov_astra2013.pdf (2.9 Mo) Télécharger le fichier
hal-00821221 , version 1 (08-05-2013)
  • HAL Id : hal-00821221 , version 1
Vincent Acary, Maurice Brémond, Konstantinos Kapellos, Jan Michalczyk, Roger Pissard-Gibollet. Mechanical simulation of the Exomars rover using Siconos in 3DROV. ASTRA 2013 - 12th Symposium on Advanced Space Technologies in Robotics and Automation, ESA/ESTEC, May 2013, Noordwijk, Netherlands. ⟨hal-00821221⟩
413 Consultations
591 Téléchargements
