Finite Element Hodge for Spline Discrete Differential Forms. Application to the Vlasov-Poisson Equations.
The notion of B-spline based discrete differential forms is recalled and along with a Finite Element Hodge operator, it is used to design new numerical methods for solving the Vlasov-Poisson equations.
