SPLINE DISCRETE DIFFERENTIAL FORMS AND A NEW FINITE DIFFERENCE DISCRETE HODGE OPERATOR - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
We construct a new set of discrete differential forms based on B-splines of arbitrary degree as well as an associated Hodge operator. The theory is first developed in 1D and then extended to multi-dimension using tensor products. We link our discrete differential forms with the theory of chains and cochains. The spline discrete differential forms are then applied to the numerical solution of Maxwell's equations.
sddf_soumis.pdf (1.71 Mo) Télécharger le fichier
hal-00822164 , version 1 (18-06-2013)
hal-00822164 , version 2 (13-11-2014)
  • HAL Id : hal-00822164 , version 2
Aurore Back, Eric Sonnendrücker. SPLINE DISCRETE DIFFERENTIAL FORMS AND A NEW FINITE DIFFERENCE DISCRETE HODGE OPERATOR. 2014. ⟨hal-00822164v2⟩
441 Consultations
252 Téléchargements
