Pattern-based ontology transformation service - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Many use cases for semantic technologies (eg. reasoning, modularisation, matching) could benefit from an ontology transformation service. This service is supported with ontology transformation patterns consisting of corresponding ontology patterns capturing alternative modelling choices, and an alignment between them. In this paper we present the transformation process together with its two constituents: a pattern detection and an ontology transformation process. The pattern detection process is based on SPARQL and the transformation process is based on an ontology alignment representation with specific extensions regarding detailed information about the transformation.
zamazal2009b.pdf (150.45 Ko) Télécharger le fichier
hal-00822899 , version 1 (15-05-2013)
  • HAL Id : hal-00822899 , version 1
Ondrej Sváb-Zamazal, Vojtech Svátek, François Scharffe. Pattern-based ontology transformation service. Proc. 1st IK3C international conference on knowledge engineering and ontology development (KEOD), Oct 2009, Funchal, Portugal. pp.210-223. ⟨hal-00822899⟩
173 Consultations
147 Téléchargements
