Reduced-bias estimator of the Conditional Tail Expectation of heavy-tailed distributions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2015
Several risk measures have been proposed in the literature. In this paper, we focus on the estimation of the Conditional Tail Expectation (CTE). Its asymptotic normality has been first established in the literature under the classical assumption that the second moment of the loss variable is finite, this condition being very restrictive in practical applications. Such a result has been extended by Necir {\it et al.} (2010) in the case of infinite second moment. In this framework, we propose a reduced-bias estimator of the CTE. We illustrate the efficiency of our approach on a small simulation study and a real data analysis.
CTE-Guillou.pdf (234.7 Ko) Télécharger le fichier
hal-00823260 , version 1 (16-05-2013)
hal-00823260 , version 2 (23-09-2013)
El Hadji Deme, Stéphane Girard, Armelle Guillou. Reduced-bias estimator of the Conditional Tail Expectation of heavy-tailed distributions. M. Hallin et al. Mathematical Statistics and Limit Theorems, Springer, pp.105-123, 2015, ⟨10.1007/978-3-319-12442-1_7⟩. ⟨hal-00823260v2⟩
536 Consultations
762 Téléchargements
