Image characterization and classification by physical complexity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Complexity Année : 2012
We present a method for estimating the complexity of an image based on Bennett's concept of logical depth. Bennett identified logical depth as the appropriate measure of organized complexity, and hence as being better suited to the evaluation of the complexity of objects in the physical world. Its use results in a different, and in some sense a finer characterization than is obtained through the application of the concept of Kolmogorov complexity alone. We use this measure to classify images by their information content. The method provides a means for classifying and evaluating the complexity of objects by way of their visual representations. To the authors' knowledge, the method and application inspired by the concept of logical depth presented herein are being proposed and implemented for the first time
halsde-00733599 , version 1 (19-09-2012)
Hector Zenil, Cédric Gaucherel, Jean-Paul Delahaye. Image characterization and classification by physical complexity. Complexity, 2012, 17 (1), pp.26-42. ⟨10.1002/cplx.20388⟩. ⟨halsde-00733599⟩
240 Consultations
0 Téléchargements
