Impact-contact dynamics in a disc-ball system - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Proceedings of the Royal Society A: Mathematical, Physical and Engineering Sciences Année : 2013
This paper concerns a disc-ball system, in which a moving ball collides against a disc resting on a rough, fixed horizontal surface. The complexity in such a simple object is due to the presence of the line contact between the disc and the fixed plate, which significantly influences the impact-generated state of the disc. We deal with this problem in a uniform framework that encapsulates different structures of the mathematical model, including contacts, impacts, stick-slip in friction, as well as the transitions among different states of the variable-structure dynamics. We design specific experiments that provide useful information to help determine the macroscopic parameters in impact and friction. Other complicated cases concerned with the couplings between impacts and friction are theoretically and experimentally investigated. Excellent agreements between numerical and experimental results support our theoretical developments.
liu2013.pdf (767.9 Ko) Télécharger le fichier
hal-00825597 , version 1 (10-11-2017)
Caishan Liu, Hongjian Zhang, Zhao Zhen, Bernard Brogliato. Impact-contact dynamics in a disc-ball system. Proceedings of the Royal Society A: Mathematical, Physical and Engineering Sciences, 2013, 469 (2152), pp.20. ⟨10.1098/rspa.2012.0741⟩. ⟨hal-00825597⟩
340 Consultations
131 Téléchargements
