Existence, uniqueness of solutions and stability of nonsmooth multivalued Lur'e dynamical systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Convex Analysis Année : 2013
This paper deals with the well-posedness of a class of multivalued Lur'e systems, which consist of a nonlinear dynamical system in negative feedback interconnection with a static multivalued nonlinearity. The objective is to provide a detailed analysis of the conditions which guarantee that a certain operator, constructed from the static nonlinearity, is maximal monotone. This in turn assures the existence and the uniqueness of the solutions. Examples (nonlinear complementarity systems, nonlinear relay systems) illustrate the developments. A stability result is also given.
BBDG.pdf (177.12 Ko) Télécharger le fichier
hal-00825601 , version 1 (03-11-2017)
  • HAL Id : hal-00825601 , version 1
Bernard Brogliato, Daniel Goeleven. Existence, uniqueness of solutions and stability of nonsmooth multivalued Lur'e dynamical systems. Journal of Convex Analysis, 2013, 20 (3), pp.881-900. ⟨hal-00825601⟩
333 Consultations
187 Téléchargements
