Improving Modular Inversion in RNS using the Plus-Minus Method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The paper describes a new RNS modular inversion algorithm based on the extended Euclidean algorithm and the plus-minus trick. In our algorithm, comparisons over large RNS values are replaced by cheap computations modulo 4. Comparisons to an RNS version based on Fermat's little theorem were carried out. The number of elementary modular operations is signi cantly reduced: a factor 12 to 26 for multiplications and 6 to 21 for additions. Virtex 5 FPGAs implementations show that for a similar area, our plus-minus RNS modular inversion is 6 to 10 times faster.
article.pdf (527.64 Ko) Télécharger le fichier
hal-00825745 , version 1 (24-05-2013)
Karim Bigou, Arnaud Tisserand. Improving Modular Inversion in RNS using the Plus-Minus Method. CHES - 15th Workshop on Cryptographic Hardware and Embedded Systems - 2013, Aug 2013, Santa Barbara, United States. pp.233-249, ⟨10.1007/978-3-642-40349-1_14⟩. ⟨hal-00825745⟩
414 Consultations
484 Téléchargements
