Explicit Nonlinear Model Predictive Control of the Air Path of a Turbocharged Spark-Ignited Engine - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Jamil El Hadef
  • Fonction : Auteur
  • PersonId : 934458
Guillaume Colin
Yann Chamaillard
Vincent Talon
  • Fonction : Auteur
  • PersonId : 922613
Pollutant emissions and fuel economy objectives have led car manufacturers to develop innovative and more sophisticated engine layouts. In order to reduce time-to-market and development costs, recent research has investigated the idea of a quasi-systematic engine control development approach. Model based approaches might not be the only possibility but they are clearly predetermined to considerably reduce test bench tuning work requirements. In this paper, we present the synthesis of a physics-based nonlinear model predictive control law especially designed for powertrain control. A binary search tree is used to ensure real-time implementation of the explicit form of the control law, computed by solving the associated multi-parametric nonlinear problem.
2013_MSC_ElHadef.pdf (259.74 Ko) Télécharger le fichier
hal-00920493 , version 1 (18-12-2013)
Jamil El Hadef, Sorin Olaru, Pedro Rodriguez-Ayerbe, Guillaume Colin, Yann Chamaillard, et al.. Explicit Nonlinear Model Predictive Control of the Air Path of a Turbocharged Spark-Ignited Engine. 2013 IEEE International Conference on Control Applications (CCA), Aug 2013, Hyderabad, India. pp.71-77, ⟨10.1109/CCA.2013.6662746⟩. ⟨hal-00920493⟩
273 Consultations
473 Téléchargements
