Generalizing Bounds on the Minimum Distance of Cyclic Codes Using Cyclic Product Codes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Two generalizations of the Hartmann--Tzeng (HT) bound on the minimum distance of q-ary cyclic codes are proposed. The first one is proven by embedding the given cyclic code into a cyclic product code. Furthermore, we show that unique decoding up to this bound is always possible and outline a quadratic-time syndrome-based error decoding algorithm. The second bound is stronger and the proof is more involved. Our technique of embedding the code into a cyclic product code can be applied to other bounds, too and therefore generalizes them.
hal-00828083 , version 1 (26-06-2013)
Alexander Zeh, Antonia Wachter-Zeh, Maximilien Gadouleau, Sergey Bezzateev. Generalizing Bounds on the Minimum Distance of Cyclic Codes Using Cyclic Product Codes. IEEE International Symposium on Information Theory (ISIT), Jul 2013, Istanbul, Turkey. pp.1-6. ⟨hal-00828083⟩
368 Consultations
0 Téléchargements
