Characterization of whole plant leaf area properties using laser scanner point clouds - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Whole plant leaf area properties were extracted from contrasting laser scanner point clouds of herbaceous plants and compared to information obtained by 3D magnetic digitization. Total leaf area and its spatial distribution were strongly related to the total number of scanned points and its spatial distribution. The calculations of point normals allowed, to some extend, to infer the distribution of plant surfaces elevation angles. Together with the definition of an accurate plant boundary envelope, these data allowed the calculation of light interceptions as accurately as magnetic digitization by using simpler turbid medium plant representations
Louarn-PMA12poster.pdf (109.81 Ko) Télécharger le fichier
Format : Figure, Image
hal-00828841 , version 1 (31-05-2013)
  • HAL Id : hal-00828841 , version 1
Gaëtan Louarn, Serge Carré, Frédéric Boudon, Annie Eprinchard, Didier Combes. Characterization of whole plant leaf area properties using laser scanner point clouds. Fourth International Symposium on Plant Growth Modeling, Simulation, Visualization and Applications, 2012, Shanghai, China. ⟨hal-00828841⟩
308 Consultations
802 Téléchargements
