Error estimation in the Computation of Induced Current of Human Body in the Case of Low frequency Magnetic Field Excitation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Computation of induced current in human body with FEM requires an important computation time. To avoid this difficulty the phi-A formulation has been proposed and its efficiency have been demonstrated. Nevertheless as the accuracy of the solution is in direct link with the mesh we propose to evaluate the numerical solution with a posteriori error estimator.
Fichier non déposé
hal-00829296 , version 1 (03-06-2013)
  • HAL Id : hal-00829296 , version 1
Thomas Lelong, Zuqi Tang, Riccardo Scorretti, Pierre Thomas, Yvonnick Le Menach, et al.. Error estimation in the Computation of Induced Current of Human Body in the Case of Low frequency Magnetic Field Excitation. Compumag 2013, Jun 2013, Budapest, Hungary. pp.PC1-11. ⟨hal-00829296⟩
390 Consultations
0 Téléchargements
