Approximate stabilization of an infinite dimensional quantum stochastic system - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Reviews in Mathematical Physics Année : 2013
We study the state feedback stabilization of a quantum harmonic oscillator near a pre-specified Fock state (photon number state). Such a state feedback controller has been recently implemented on a quantized electromagnetic field in an almost lossless cavity. Such open quantum systems are governed by a controlled discrete-time Markov chain in the unit ball of an infinite dimensional Hilbert space. The control design is based on an unbounded Lyapunov function that is minimized at each time-step by feedback. This ensures (weak-*) convergence of probability measures to a final measure concentrated on the target Fock state with a pre-specified probability. This probability may be made arbitrarily close to 1 by choosing the feedback parameters and the Lyapunov function. They are chosen so that the stochastic flow that describes the Markov process may be shown to be tight (concentrated on a compact set with probability arbitrarily close to 1). Convergence proof uses Prohorov's theorem and specific properties of this Lyapunov function.
StabilizationQuantum.pdf (235.22 Ko) Télécharger le fichier
hal-00829864 , version 1 (04-06-2013)
Ram Abhinav Somaraju, Mazyar Mirrahimi, Pierre Rouchon. Approximate stabilization of an infinite dimensional quantum stochastic system. Reviews in Mathematical Physics, 2013, 25 (1), pp.1350001. ⟨10.1142/S0129055X13500013⟩. ⟨hal-00829864⟩
226 Consultations
177 Téléchargements
