GEOMETRIC TWO-SCALE CONVERGENCE ON MANIFOLD AND APPLICATIONS TO THE VLASOV EQUATION. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete and Continuous Dynamical Systems - Series S Année : 2015
We develop and we explain the two-scale convergence in the covariant formalism, i.e. using di erential forms on a Riemannian manifold. For that purpose, we consider two manifolds M and Y , the rst one contains the positions and the second one the oscillations. We establish some convergence results working on geodesics on a manifold. Then, we apply this framework on examples.
back.pdf (387.1 Ko) Télécharger le fichier
hal-00833192 , version 1 (18-06-2013)
  • HAL Id : hal-00833192 , version 1
Aurore Back, Emmanuel Frenod. GEOMETRIC TWO-SCALE CONVERGENCE ON MANIFOLD AND APPLICATIONS TO THE VLASOV EQUATION.. Discrete and Continuous Dynamical Systems - Series S, 2015, Special Issue on "Numerical Methods Based on Two-Scale Convergence and Homogenization", 8 (1), pp 223--241. ⟨hal-00833192⟩
454 Consultations
329 Téléchargements
