A Variational Finite Element Model for Large-Eddy Simulations of Turbulent Flows - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Chinese Annals of Mathematics - Series B Année : 2013
We introduce a new Large Eddy Simulation model in a channel, based on the projection on finite element spaces as filtering operation in its variational form, for a given triangulation $\{{\cal T}_h \}_{h>0}$. The eddy viscosity is expressed in terms of the friction velocity in the boundary layer due to the wall, and is of a standard sub grid-model form outside the boundary layer. The mixing length scale is locally equal to the grid size. The computational domain is the channel without the linear sub-layer of the boundary layer. The no slip boundary condition (BC) is replaced by a Navier (BC) at the computational wall. Considering the steady state case, we show that the variational finite element model we have introduced, has a solution $(\vv_h, p_h)_{h>0}$ that converges to a solution of the steady state Navier-Stokes Equation with Navier BC.
hal-00833231 , version 1 (12-06-2013)
Tomas Chacon-Rebollo, Roger Lewandowski. A Variational Finite Element Model for Large-Eddy Simulations of Turbulent Flows. Chinese Annals of Mathematics - Series B, 2013, 34 (5), pp.667-682. ⟨10.1007/s11401-013-0796-6⟩. ⟨hal-00833231⟩
501 Consultations
0 Téléchargements
