A Distributed Program Global Execution Control Environment Applied to Load balancing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Scalable Computing : Practice and Experience Année : 2012
The paper is concerned with a new distributed program design environment based on the global application states monitoring. The environment called PEGASUS (from Program Execution Governed by Asynchronous SUpervision of States) supplies to a programmer a ready to use control primitives to design distributed program execution control in which decisions for synchronous and asynchronous control actions are based on predicates evaluated on global application states. Such strongly consistent global application states are automatically constructed by the run-time system which additionally provides mechanisms for their analysis and organizing the respective program execution control in processes and threads of user programs executed in multicore processors. The PEGASUS control mechanisms are graphically supported in the respective program design framework. The paper first presents main general features of the PEGASUS environment. Next, it presents a method for load balancing inside distributed programs based on a set of parameters which are dynamically measured during program execution. Then, the paper presents how the described load balancing method can be implemented inside the PEGASUS environment taking as an example distributed programs for solving the Traveling Salesman Problem (TSP).
797-442-1-PB.pdf (834.69 Ko) Télécharger le fichier
hal-00833488 , version 1 (12-06-2013)
  • HAL Id : hal-00833488 , version 1
Janusz Borkowski, Damian Kopanski, Eryk Laskowski, Richard Olejnik, Marek Tudruj. A Distributed Program Global Execution Control Environment Applied to Load balancing. Scalable Computing : Practice and Experience, 2012, 13 (3), pp.ISSN 1895-1767. ⟨hal-00833488⟩
237 Consultations
122 Téléchargements
