Signal detection using watermark insertion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper analyses signal detection using watermark insertion, which is artificially embedded into the digital modulated signal. When a signal does not contain intrinsic information, its detection is hard to achieve using blind detectors. For that kind of signals, we propose to insert a low-power watermark that will be detected by a matched filter based detector. The system design is a trade-off between the watermark insertion strength (i.e. reducing the transmission quality) and the detection sensitivity. This trade-off is discussed in this paper and simulations results show the advantage of the watermarkinsertion.
Gautier_VTC13_Watermarking.pdf (307.87 Ko) Télécharger le fichier
hal-00833552 , version 1 (13-06-2013)
  • HAL Id : hal-00833552 , version 1
Matthieu Gautier, Dominique Noguet. Signal detection using watermark insertion. IEEE International Vehicular Technology conference (VTC-Spring13), Jun 2013, Dresden, France. pp.11. ⟨hal-00833552⟩
369 Consultations
322 Téléchargements
