Comparison and Analysis of Several Phonetic Decoding Approaches - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This article analyzes the phonetic decoding performance obtained with different choices of linguistic units. The context is to later use such an approach as a support for helping communication with deaf people, and to run it on an embedded decoder on a portable terminal, which introduces constrains on the model size. As a first step, this paper compares the performance of various approaches on the ESTER2 and ETAPE speech corpora. Two baseline systems are considered, one relying on a large vocabulary speech recognizer, and another one relying on a phonetic n-gram language model. The third model which relies on a syllable-based lexicon and a trigram language model, provides a good tradeoff between model size and phonetic decoding performance. The phone error rate is only 4% worse (absolute) than the phone error rate obtained with the large vocabulary recognizer, and much better than the phone error rate obtained with the phone n-gram language model. Phone error rates are then analyzed with respect to SNR and speaking rate.
articleTSD2013_#98-Luiza-Orosanu-final.pdf (165.12 Ko) Télécharger le fichier
hal-00834313 , version 1 (25-03-2016)
  • HAL Id : hal-00834313 , version 1
Luiza Orosanu, Denis Jouvet. Comparison and Analysis of Several Phonetic Decoding Approaches. TSD - 16th International Conference on Text, Speech and Dialogue - 2013, Sep 2013, Pilsen, Czech Republic. pp.161-168. ⟨hal-00834313⟩
173 Consultations
93 Téléchargements
