A Reconfigurable Camera Add-On for High Dynamic Range, Multispectral, Polarization, and Light-Field Imaging - Inria - Institut national de recherche en sciences et technologies du numérique
Article Dans Une Revue ACM Transactions on Graphics Année : 2013
We propose a non-permanent add-on that enables plenoptic imaging with standard cameras. Our design is based on a physical copying mechanism that multiplies a sensor image into a number of identical copies that still carry the plenoptic information of interest. Via different optical filters, we can then recover the desired information. A minor modification of the design also allows for aperture subsampling and, hence, light-field imaging. As the filters in our design are exchangeable, a reconfiguration for different imaging purposes is possible. We show in a prototype setup that high dynamic range, multispectral, polarization, and light-field imaging can be achieved with our design.
KaleidoCamera-Manakov2013.pdf (10.46 Mo) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-00835898 , version 1 (20-06-2013)
Alkhazur Manakov, John Restrepo, Oliver Klehm, Ramon Hegedus, Elmar Eisemann, et al.. A Reconfigurable Camera Add-On for High Dynamic Range, Multispectral, Polarization, and Light-Field Imaging. ACM Transactions on Graphics, 2013, Proceeding of SIGGRAPH, 32 (4), pp.47:1-47:14. ⟨10.1145/2461912.2461937⟩. ⟨hal-00835898⟩
Relations
More
